So Subaru shop said normal, Driveline shop said it's terrible & needs replacing.
I pulled it apart for a look myself, when assembled it feels like the roll pins are the only piece holding it together, once shaft is pulled & putting CV back onto Diff shaft there is definite play in the splines, but they do mesh together but not like any spline i've ever felt.
Feels like drive is transmitted through the splines although there is movement there, & roll pin just stop it coming off like a normal splines circlip would.
So how much play is to much between these splines, with CV fitted & grabbing the whole CV it moves maybe 5mm vertically ?
Diff.
Inside inner CV
