EA81 Rocker Spacer
dodgybrumby
EA81 Rocker Spacer
Post by dodgybrumby » Sun Jul 27, 2014 7:39 pm
Hi all,
well gave the old girl a tidy up on the weekend by replacing the front crank seal and resealing the oil pump and valve set check. Found excess movement in the intake rocker arm on the RH rear cylinder. Noticed that the spacer has been worn down and is now to narrow to space the two inlet rockers apart correctly. The 'wave' washers dont even touch now. And now the rocker arm is been pushed further down the shaft toward the front of the engine due to not been square with the pushrod, increasing wear.
So has anyone got one lying around that i can have/buy? Or one they can take measurements/photos so that i can make one at work.
THanks
justincase41
Post by justincase41 » Sun Jul 27, 2014 8:36 pm
Where about's in Qld are you located? I've got a couple spare sets of rockers here. You can have them for nothing, just pay postage
cheers
Justin
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
dodgybrumby
Post by dodgybrumby » Sun Jul 27, 2014 8:56 pm
Warner 4500. Work at port of Brisbane. If your local in Brissy I can pick up or shoot me a PM and I can throw you some postage.
Nick
