Anyone know of a good conatact for aftermarket ring gears ?For EA81 ?
Reckon they'd be same as EA82 manual flys as well.
Got my 225mm flywheel stone ground for clutch face, then off to a good fella with a lathe who either needs to make an adaptor to turn the 23mm step down to 21mm inside the ring gear OR remove ring gear for a few dodgy spots on it, stone grind to 21mm, then new ring gear is the old perfectionists recommendation. Got meself a bit of credit with this fella - doesn't wanna be paid
Rang the usual nation wide suppliers of many parts on a Friday arvo - both need to make a call next week - no listing! Think I'd prefer to buy direct .
EA81 fly ring gear new sources?
Just stock up on old EA81 (8" or 9") flywheels and when you need one, just remove the ring gear, flip it over and reposition in a 45deg from original position but can't see you needing to do it too often.. how long have they been lasting for now?
