Smokey motor... oil/addative suggestions.
Posted: Fri Jun 02, 2006 9:35 pm
by SuBaRiNo
My ej22 is getting a little smokey at times and i can't afford to fix it or replace it.... any suggestions on what oil or addative others have used with good results that can pro-long needing to spend big money on it?
Maybe even an addative and oil combo that works well.
Dave
Posted: Fri Jun 02, 2006 10:53 pm
by waggaclint
ive used [nulon stop smoke] i reckon it works. i used to have an old falcon that was smokey and it fixed it also penrite oil cant remember witch grade but it worked
Posted: Mon Jun 05, 2006 8:01 pm
by Craigus
Try Shell Helix or Penzoil, 20W-60.
Posted: Tue Jun 06, 2006 7:19 pm
by SuBaRiNo
Funny u should suggest that... i just tried the shell Helix with the Nulon stop smoke... but no luck im afraid... engine is stuffed beyond thicker oil.
Thanks for the suggestions.
Dave
Posted: Tue Jun 06, 2006 8:41 pm
by BaronVonChickenPants
When I was getting desperate with one of my previous engines I was using straight 50 or 60 grade and even diff oil, they all went straight through (it was royally stuffed) the stop smoke addatives did just that, stopped the smoke, the oil still disappeared at the same rate though.
Jordan.
