Flywheel bolts
choinka
Flywheel bolts
Post by choinka » Fri Nov 04, 2005 1:46 pm
Does anyone have a spare set of 8 bolts to bolt up a flywheel for the manual box. I was given the flywheel, clutch and pressure plate and didn't realise the bolts are shorter for the auto box. I've pulled out the auto box which has been planned for the last 6 months, and with the auto out, have come across this small hitch.
So if you have a set not doing anything I'd happily grab them (hopefully Sydney or surrounds - I'll be in Central Coast on Saturday, so anyone there ???), otherwise it's off to Pick and Payless on Sunday.
Richard
Guest
Post by Guest » Fri Nov 04, 2005 4:32 pm
If you could find what the thread is would you be better off getting a set of 10.8s or something from your local Blackwoods?
