'87 Brumby carby problem
Posted: Sun Sep 17, 2006 3:36 pm
Hi guys, I'm from the RS Liberty club, I have a 1.8L '87 Brumby as a run around while I'm looking for another Liberty but it's running really bad. The guys from the RS club suggested I try here for some help. Keep in mind I don't know much about carbys as this is the first one I've worked on.
The Brumby uses heaps of fuel (over 15L/100kms in a 900kg car!) and pretty much won't drive without the choke on, which is probably part of the reason it uses so much fuel.
The only stuff I know about carbys has been learnt since I got this car but I have a friend that knows a bit, we put a gasket kit through it and a new plunger and cleaned the jets and all that sort of stuff but it didn't help. I've also done an oil change and replaced the fuel filter. The timing was advanced about ten degrees too much and we think this is because the vacuum advance isn't working so the last owner advanced the timing to make up for it (the previous owner was the dumbest lowlife piece of sh*t I've ever met).
The secondary butterfly (I think that's what it's called) doesn't seem to be opening when revving the car and there doesn't seem to be any vacuum getting to it. We think there's a vacuum fitting blocked inside the carby that both the vacuum advance and secondary butterfly are run off. If we hook them both up to a normal vacuum line we can see the butterfly open right up and the car instantly revs it's head off so we're guessing the vacuum fitting has some sort of valve to control the amount of vacuum. We tried blowing the vacuum fitting out with compressed air but that didn't work.
Can anyone help? Is this a normal problem and does it sound like a blockage? If so is it likely that we would be able to get to it to unblock it if we pulled the carby appart?
I got prices on some carbys from wreckers but they were $80-$95 which I don't want to spend if I don't have to especially considering they may have their own problems. Any help would be much appreciated.
