AWD BOX
Posted: Sun Nov 06, 2005 9:00 pm
by dr650
How can you tell if the l series and an awd box or part time 4wd box are the numbers different??? thanks for any help
Posted: Sun Nov 06, 2005 10:21 pm
by Shorty
in the part time it will have a lever to select 4wd if no lever then u have awd
hehe and that is coming from a girl
Take Care
Shorty
Posted: Mon Nov 07, 2005 5:26 am
by Fang
There are a few things you can look for
The gold vaccuum diaphragm -: Used to Lock the Centre Diff. Dont look for this alone - Single Range P/T 4WD boxes had this too
Count the splines on the front drive output - there should be 25 not 23. Does not necessarily means its AWD tho - 25 splines just means its an RX box. All L Series AWD boxes have 25 splines.
The definiatave way I told was by turning the input shaft. I selected the rod/levers in all positions - and the 3 output shafts always turned. If you have 25 splines and the diaphragm - then its AWD.
Shorty is correct - there should be no rod for selecting 4WD - but if its dual range there will be a rod for Hi/Lo Range selection. If it has a rod, it should only have 2 positions - not 3. 3 positions is for Part Time 4WD
I believe the external case is the same for AWD and Part Time 4WD.
Maybe someone else can hook you with numbers, etc
Posted: Mon Nov 07, 2005 9:00 am
by Ben
Easiest way is to look for the difflock - on the drivers side of the box near the mount bracket there is a lever that is actuated by the cable going to the vacuum diaphragm, if you have that lever it's an L series awd box.
Also, next to a part time box, the centre diff housing at the back is *clearly* bigger and different shaped.
Posted: Mon Nov 07, 2005 9:02 am
by Ben
Shorty wrote:in the part time it will have a lever to select 4wd if no lever then u have awd
Take Care
Shorty
If its a d/r awd box you still have the lever to select hi/low, it still goes through the box the same as the 4wd selector on the part time box, only instead of engaging 4wd (under the gold inspection plate) it just passes through.
Posted: Mon Nov 07, 2005 10:38 am
by Fang
MechaWagon wrote:Easiest way is to look for the difflock - on the drivers side of the box near the mount bracket there is a lever that is actuated by the cable going to the vacuum diaphragm, if you have that lever it's an L series awd box.
Correct me if I am wrong - but wouldnt a single range 4WD box have the same setup??
Posted: Mon Nov 07, 2005 2:35 pm
by Ben
Nope, the entry point for the selector that operates the difflock is nowhere near the 4wd actuator. The difflock one is near the bottom.
Posted: Mon Nov 07, 2005 5:06 pm
by Fang
Okay - thanks for clarifying that.
Posted: Tue Nov 08, 2005 9:16 pm
by dr650
Thanks for your help now i can tell the difference..
Posted: Sun Nov 13, 2005 7:10 pm
by AlpineRaven
Was there any EA82 AWD boxes (not from Liberty) that was sold in Australia?
As far I know from what I heard that AWD were not sold in Aus for EA82s. EJ series AWD boxes does not fit on EA82 engine correct?
Posted: Sun Nov 13, 2005 7:31 pm
by Fang
Correct AlpineRaven - the Full Time 4WD box (AWD) was never sold in L Series in Australia.
Not sure about the EJ adaptation...
Posted: Sun Nov 13, 2005 10:10 pm
by BaronVonChickenPants
The EJ boxes will not directly bolt up to an EA8x engine, you'll need to use an adaptor plate, as well as modified CV and tail shafts.
If you're going to all that effort you might as well drop an EJ engine in there while you're at it, then you only need to modify the shafts.
Jordan.
Posted: Sun Nov 13, 2005 10:20 pm
by Guest
Fang wrote:the Full Time 4WD box (AWD) was never sold in L Series in Australia.
What about the L-Series turbo automatics? I think the later ones came Aus-delivered AWD Automatic. I'm also thinking Vortex, but I'm not sure if any were from Australian dealers.
I'm probably totally wrong though, just a thought.
Posted: Sat Nov 19, 2005 1:30 pm
by adam_rxturbo
i've got a awd single range centre locking box
was for sale for $300 but you're all too slow and its now in my car
I think they came out of an imported L series RX turbo or something...
And yes the end housing is longer and a different shape.
-Adam
Posted: Sat Nov 19, 2005 4:39 pm
by Fang
Who's "you all", fella??
I have a dual range version AWD going into my L in a shortly.
Posted: Sat Nov 19, 2005 11:42 pm
by wagonist
Just to be a technical bastard, but the term Subaru used for the AWD L series boxes is "Full-Time 4wd".
I personally thin kwe should stick to that because it separates the mechanical centre diff boxes from the viscous EJ AWD type.
Weren't the 4wd Vortexes single range full-time 4wd?
Posted: Sun Nov 20, 2005 7:47 am
by Fang
EXACTLY RIGHT! - I was using that term coz it simplified things. Sounded like we were talking bout two different boxes
