Auto Gearbox EA82T
Rabbitoh
Auto Gearbox EA82T
Post by Rabbitoh » Sun Nov 05, 2006 7:04 pm
Hi all,
I'm hoping someone can answer this problem. I put an EA82T engine into a L series sedan , auto gearbox. Upon heavy accelaration the car jolts, normal acceleration it is fine. Is this "kick down" can it be adjusted as this is a most annoying problem, aside from that the car goes great. Any help appreciated, thanks.
stamp_licker
Post by stamp_licker » Sun Nov 05, 2006 8:41 pm
could be kickdown.did you use the ea82T torque converter? They tend to liven up things a little.
Building a hardcore postie:D
Rabbitoh
Auto Gearbox EA82T
Post by Rabbitoh » Mon Nov 06, 2006 5:11 am
No I didn't. Where can I get one fitted in Sydney, is this an expensive exercise?
Thanks.
cruzingbrumby
Post by cruzingbrumby » Mon Nov 06, 2006 7:28 am
I have a torque converter from a 4 spd AWD auto, you can have it if you come pick it up
Rabbitoh
Auto Gearbox EA82T
Post by Rabbitoh » Mon Nov 06, 2006 4:39 pm
I have found out that a turbo modulator is needed as well as checking the vacuum pressure. So I will follow up on these two things first. THanks
