Stripped Spark Plug
Posted: Tue Nov 07, 2006 9:45 pm
by lukes6
Just after some advice i have got an EJ22 in a liberty that now has a stripped sparkplug hole.
It literally blew the plug out under its own power.
Just looking to find out if anyone has had any luck with using a helicoil to repair such a problem or whether i would be better off looking for another head to put on it.
Any tips would be great
Posted: Tue Nov 07, 2006 10:23 pm
by Subafury
i dont know if it'll help in this situation but there is some stuff u can buy to repair stripped threads. u like put the putty in the hole and the bolt thread and it like makes a new thread. dont know if it'll be resistant to high heats in the head tho and dont know how good it actually works. but yeh my 2c
Posted: Tue Nov 07, 2006 10:44 pm
by Suby Wan Kenobi
Installing a helicoil is pretty easy and reliable way to fix the problem just make sure you get all the shavings out of the bore before starting the engine
Posted: Tue Nov 07, 2006 11:11 pm
by subelover
yep def i have stuffed many a thread and helicoils have always been good...did a head on an ea82 and stripped 1 hole..when the car came back in for a retension and checkover all good no probs with it had a geeza...my 2c cheers BEN
Posted: Wed Nov 08, 2006 9:31 am
by Shauno
Helicoils FTW!
Posted: Wed Nov 08, 2006 12:20 pm
by daza
Shauno wrote:Helicoils FTW!
lol
Daza.
Posted: Wed Nov 08, 2006 4:32 pm
by lukes6
Looks like a helicoil will be the first thing i try then.
The next question is can they be put in without taking the head off?
The plug seat is a long way in and how would you stop shaving going into the bore?
Cheers for you help guys
Posted: Wed Nov 08, 2006 4:37 pm
You'll have to vacuum out the shavings. Use a small hose that fits down the spark plug hole and fix it to the vacuum hose. Just make sure you do a good job of it.
If you could be bothered with the trauma of taking off the head and want the piece of mind that there's no shavings in the cylinder/chamber, go that way.
