stamp_licker
Post
by stamp_licker » Sat Nov 11, 2006 11:37 am
How high do these boxes " stall up"?The revs seem to go a bit higher before the thing starts moving to what i'm used to.Also how do you find the shifting in them?
Building a hardcore postie:D
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Sat Nov 11, 2006 9:06 pm
The stall on my TT was only about 1700rpm ish before it wanted to move forward no matter how much brake i used. The change very crisply no spongy gear changing can seem harsh at times.
The long road ahead
Subaman
Post
by Subaman » Sun Nov 12, 2006 6:44 am
Brett and I tested his the otherday, seems to be around 2400 to 2700 rpm.
Chris_Rogers
Post
by Chris_Rogers » Sun Nov 12, 2006 8:23 am
where do the normal ones shift at? (about to try mine.)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
2006 Holden Combo - work van
vincentvega
Post
by vincentvega » Sun Nov 12, 2006 6:27 pm
this all depends on what engine you have behind it.
NA engine is going to stall up sooner than a TT or EJ25T in bretts case
what RPM are you stalling to postie??? The more the better for offroading
stamp_licker
Post
by stamp_licker » Sun Nov 12, 2006 6:29 pm
i'm thinking the tranny fluid might be to low car sitting cold way over the top of the hot full mark.start it up after a bit of rattling from the torque conv it shows nothing on the dipstick.Don't think its stalling could be slipping
Chris_Rogers
Post
by Chris_Rogers » Sun Nov 12, 2006 8:37 pm
part of the reason I asked. if its like any of the chev stuff I'm used to by 2k it should be moving.
will,
going to see your mate in b'gary. I think mine is going to need a tidyup anyway. (car arrives in the morn.)
Audio Express
Outback bloke
Post
by Outback bloke » Mon Nov 13, 2006 5:40 am
Mine will drive off at 1200rpm but if I stall it up I can't hold it at the numbers already mentioned.
vincentvega
Post
by vincentvega » Mon Nov 13, 2006 9:02 am
those numbers are pretty high for a stock converter brett... but you are making alot of torque down low.
If you were to stick the same box in grants car it would probably only stall up to 2000 or so
stamp_licker
Post
by stamp_licker » Tue Nov 14, 2006 5:06 am
1000 and below tc is no good,1800 is normal
Outback bloke
Post
by Outback bloke » Tue Nov 14, 2006 5:50 am
The box in my car seems to be doing every thing as it should but it was the biggest mistake I ever made. I don't like it and have wondered how I am going to sell the car. Time for a new one. A manual one.
vincentvega
Post
by vincentvega » Tue Nov 14, 2006 10:38 am
hahahahahaha
poor old brett
you had it on the beach yet? You will change your mind...
Chris_Rogers
Post
by Chris_Rogers » Tue Nov 14, 2006 5:00 pm
the_postie wrote:1000 and below tc is no good,1800 is normal
thanks for that.
Audio Express
Chris_Rogers
Post
BYB-01 wrote:The box in my car seems to be doing every thing as it should but it was the biggest mistake I ever made. I don't like it and have wondered how I am going to sell the car. Time for a new one. A manual one.
I agree with that sentiment however wife REFUSES to learn manual so I went auto.
Audio Express
stamp_licker
Post
by stamp_licker » Tue Nov 14, 2006 5:34 pm
chris is your auto up at b'gary?big trouble in little china here.4000 rpm 30kph at least it moves.
Chris_Rogers
Post
by Chris_Rogers » Tue Nov 14, 2006 5:38 pm
not yet. want to get it electrically sorted before I pull it out. still have a bit to do.
Audio Express
GTlegs
Post
by GTlegs » Wed Nov 15, 2006 6:24 am
Is it bad for the gear box if its stock and you stall it up?
vincentvega
Post
by vincentvega » Wed Nov 15, 2006 8:39 am
stall it up for longer than a few seconds and yeah your doing damage
its all about heat - the longer you stall it up for the more heat your generating
Suby Wan Kenobi
Post
by Suby Wan Kenobi » Wed Nov 15, 2006 11:27 am
4000rpm stall is way too high for a std one, you sure its got enough trans fluid in it?
The long road ahead
Xtreme_RX
Post
by Xtreme_RX » Wed Nov 15, 2006 11:35 am
The auto's take about approx. 5L of auto fluid to be full.......
