2nd gear gone??? me thinks
yeah. just driving this arvo, not thrashing, noticed what orriginally sounded like a vibration, seems a bit worse... quite loud grinding sound in 2nd. still grabs the gear fine, just makes an unbearable sound.... who reckons its on its way out???
09 Forester XT Touring Wagon
What is it with u and 2nd gear Vidler... wasn't it the same in your L once. Sorry im not much help with your current problem.
Dave
Dave
if there is a bad anything (noise, vibration) and it's only there in one specific gear than it's most likely a gearbox ka-put
If it helps, some guy on the Perth-wrx forum offered me a `98 wrx gearbox for $1000 the other day...
ask 4muff
he has a thing with 2nd gear in his wrx as well:D
yeah, i have seen than box advertised on their forums.... gonna try match the ratio coz i will save a few hundred on not replacing the diff.... although if i did get a new ratio, i'd have a donor lsd for the death machine:)
it may help with the argument of getting another car as well...... i need something to get my gearbox with:)
im calling that place today
are you currently running a 3.9 yeh??
Hunter S. Thompson
Hunter S. Thompson
Yeah it's final drive is probably still 3.9 (I think that's standard for an Aussie WRX of that era).
Remember the ratios of all the individual gears will also differ.
find out, it should be 3.9 less the owners chabged it at some stage... let us know and ill have a look round for ya
there is a few dccd boxes round also
Hunter S. Thompson
Hunter S. Thompson
3.9 wrx boxes suck ass man. upgrade ya running gear to newer stuff
Hunter S. Thompson
Hunter S. Thompson
4.11 or 444's are slightly better. tho im running 04 GD WRX / LIB from japan slightly better and newer, tho a ppg gearset is going to save you in the long run. dont listen to anyone else. ive done 5x 3.9's i know!
Hunter S. Thompson
Hunter S. Thompson
The gearbox cross members are the same, bolts up to the engine the same. Linkages are all the same. You will require to use new front cv’s from the GD series wrx as they use male inner’s the outers still suit the GC style hubs.. the rear diff obviously to match front diff.. also needs new cv’s same story outers will still suit the CG hubs..
Hunter S. Thompson
Hunter S. Thompson
Ahhh yes, love thy ‘innies’ *ponders* …….. ahh back to cars yeh sorry mate runs the same flywheel and clutch setup as GC wrx shaft length is the same and the tail shaft just drops out and slips n’ blots back inbluesteel wrote:hehe bloody new stuff and theyre "innies"
are the driveshaft lengths still the same? and tailshaft?
hows bout the clutch?
sorry... im only a couple months into owning a rex, still got lotsa questions
was a very quick job on my poopy car
Hunter S. Thompson
Hunter S. Thompson
