Q on half-shaft to gear box
fredsub
Post by fredsub » Sat Dec 09, 2006 4:12 pm
L-series
The centre part of the half shaft where it mounts, is that inside some bearing or something?
so it would stay in position, whilst the rear part of the half-shaft + diff is removed - and still be drivable.
Just figuring out the best and laziest way to remove the rear diff temporarily, so I can drive in FWD only whilst I sort out CIG the rear diff
The centre half shaft looks easy to dismantle - 4 obvious bolts, but to remove the whole shaft, it dont look too obvious how it gets removed from the
rear of the gear box...?
Thanks
Matt
Post by Matt » Sat Dec 09, 2006 6:28 pm
Off the top of my head the Tailshaft makes a seal against the gearbox, i.e the gearbox will leak all its oil out. MY/Brumby for sure not 100 percent on L .
"Claudia"
fredsub
Post by fredsub » Sat Dec 09, 2006 9:16 pm
Oh thanks Matt, damn, really? would it leak out in a rush ?
found my gregories manual - talks about "ensure shaft aperture is plugged", wonder what sort of plug i'm gonna need? might have to buy something..i've looked what i might have on hand to plug whatever size?
any suggestions out there?
LTurbo
Post by LTurbo » Sun Dec 10, 2006 12:00 am
fredsub wrote:Oh thanks Matt, damn, really? would it leak out in a rush ?
Yeah it comes out in a rush, it is really quite surprising when your under the car, and even more surprising how quickly one can move when you really need to.........I suggest draining the box first before you start mucking around with the shaft.
Basically the rear diff it what holds the shaft in place and sealed against the gearbox.
You could get another shaft and cut of the necessary bit to plug the hole, but then I don't know how you would hold it in place?
fredsub
Post by fredsub » Sun Dec 10, 2006 6:14 am
Thanks, gee lucky I didn't just go and try this out on the driveway!! be in trouble with oil everywhere.....I've only removed the rear axles thus far.
What yous reckon, if the half shaft is split, its joined by flange bolts on the diff side of the centre bearing, so that means the gearbox half stays in, and would hold ok?
Matt
Post by Matt » Sun Dec 10, 2006 8:53 am
You could split the uni joint at the gearbox end and cable that piece to the gearbox? In FWD it shouldn't spin, so as long as you put it in 4WD you should be right? It is a bit dodgy but you should be able to keep the car on the road.
"Claudia"
Matt
Post by Matt » Sun Dec 10, 2006 8:59 am
fredsub wrote:Thanks, gee lucky I didn't just go and try this out on the driveway!! be in trouble with oil everywhere.....I've only removed the rear axles thus far.
That should work to, just keep an eye on it
"Claudia"
Post by steptoe » Sun Dec 10, 2006 11:41 am
wire in the yoke ?? that's is a good idea so long as kept in fwd, and no friction present enough to tear it outs
stinky
Post by stinky » Sun Dec 10, 2006 1:21 pm
I'm pretty sure I remember Chubby removing the rear section of the tail shaft and not having any trouble.
