full time box to part time
Brumby Boy
Post by Brumby Boy » Mon Jan 15, 2007 11:01 pm
Hi is it possible to turn a Full time ej 4x4 box into a Part time ej 4x4 box using l series gear sets and all the other stuff?
the idea being that i can have the joys of a l series 5 speed box in my brumby with out using an adaptor plate and i can use the plathora of ej heavy duty clutches when running my ej convert.
RIP 1992 Brumby
MY_STI
Post by MY_STI » Tue Jan 16, 2007 7:39 am
Very possible, the L series gearsets will fit inside the EJ front casings, and the rear EA extension housing will bolt up.
I am currently running an EA awd internals in a lib casing with a heavy duty EJ clutch. Works a charm.
There has been some other threads covering some of the details, have a search.
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
Brumby Boy
Post by Brumby Boy » Tue Jan 16, 2007 7:53 pm
yea i have read as much as i can find about this and i know the l series ger sets fit in the liberty cases and that the l series and ej rear cases are interchangable i just havnt been able to find anywhere that sais this has been done...
RIP 1992 Brumby
wagonist
Post by wagonist » Wed Jan 17, 2007 7:32 am
The first gearbox I had was lib internals & rear case onto an L gearbox bellhousing so it'd fit onto my EA82.
It was built by someone else though & was 10 years ago, so I dare say the reverse is possible.
Personally, I'd get a Vortex 4wd extension. That way you can have full time 4wd on the road with a centre diff lock.
The lib gearset & speedo drive will also make your speedo accurate if you've got 14" wheels with the same size tyre as the Lib (which are bigger than any L or brumby)
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
