where to weld diff?
where to weld diff?
okay, so, i got the welder, i got the ability, ive had welded diffs before but never opened one up to look inside, now i want to weld up a couple more. One for the brumby, and one for subi...
so does anyone have a photo or detailed description of where i have to weld? and can it be done by just removing the cover or do i have to dismantle the whole centre?
09 Forester XT Touring Wagon
spider gears in the miuddle....cant miss
dave
dave
- tim_81coupe
Clean the spider gears well first. I'd recommend first removing the centre so you can work on it on a bench. Then clean the spider gears with spirits or petrol to get rid of any traces of diff oil. Once that's evaporated then weld up the spider gears and make sure the ring gear doesn't cop any spatter.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
http://www.ausubaru.com.au/showthread.p ... lding+diff
http://www.ausubaru.com.au/showthread.p ... =weld+diff
found a couple more hints and tips here jay
- waggaclint
ill be working on em during the week. i have a spare 3.7 diff here so ill weld that one up, then it will be a case of you coming over, then straight swap. ill give ya hand removing/installing and should take all of a couple of hours, just bring some diff oil. ill aim for saturday at the moment. will keep you posted
