Ej22 Pullys? Part Numbers?
BrennyV
Post by BrennyV » Tue Feb 20, 2007 3:05 pm
Hey guys just getting all the new bits for my ej22 from Shaun, I cant seem to get the part number for both pulleys on the ej22? Is it the same pulley for both or 2 separate ones??
Had no probs getting the timing belt and rocket cover gaskets just stuck on the pulleys
Thanks
Brendan
Hunter S. Thompson
BrennyV
Post by BrennyV » Wed Feb 21, 2007 7:05 pm
bump
anyone?
Hunter S. Thompson
Post by AndrewT » Wed Feb 21, 2007 11:12 pm
Call Subaru Melville, talk to spare parts / Milton. If he can't find the part number for you, it doesn't exist.
tim_81coupe
Post by tim_81coupe » Wed Feb 21, 2007 11:59 pm
I'll second that, Milton is a guru.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
BrennyV
Post by BrennyV » Thu Feb 22, 2007 1:16 pm
might be a goer, less dave has some spare's from his old donks?
Hunter S. Thompson
Post by AlpineRaven » Thu Feb 22, 2007 7:13 pm
'[4MUFF wrote:]Hey guys just getting all the new bits for my ej22 from Shaun, I cant seem to get the part number for both pulleys on the ej22? Is it the same pulley for both or 2 separate ones??
Thanks
Brendan
Go to..... CBC Bearings - part nbr 60TB0648E Its idler bearings you need two of them for left and right, they're both the same. Price - $34.56 + GST ($3.46) total $38 after GST. The bearing at CBC are exactly the same as Subaru ones they use NSK bearings which is what CBC supplies.
BrennyV
Post by BrennyV » Thu Feb 22, 2007 7:23 pm
cheers mate! weres cbc :/
Hunter S. Thompson
Shauno
Post by Shauno » Thu Feb 22, 2007 9:05 pm
Dwon the rd from you if im correct...
Subaru MY01 WRX - Own:twisted:
waggaclint
Post by waggaclint » Thu Feb 22, 2007 10:31 pm
if ya havnt used the belt you could always just get a t/belt kit..it will come with pulleys cam & crank seals and the belt...id also reckommend replacing the tensioner..l8tly ive seen a few fail and the belt will slip a few teeth hey...i do far few timing belts on subarus and now i always replace the tensioner hey....recommended if ya gonna flog it to hey...its up to but...
2011 Forester X
Post by AlpineRaven » Fri Feb 23, 2007 5:15 am
I didnt replace the tensioner as it felt "okay" on my previous Lib... I am not saying against the replacement - its up to you but be aware the price.
I will be replacing the tensioner & all timing belt bearings on my Lib when it reaches 300,000 kms.
