4EAT mounts..
Chris_Rogers
4EAT mounts..
Post by Chris_Rogers » Sat Mar 24, 2007 6:41 pm
how many different versions are there of these things.
the one I have has a left/centre/right mount. need one that is one piece with two holes centred on the middle of the X member.
any idea where I can find it?
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
stamp_licker
Post by stamp_licker » Sat Mar 24, 2007 7:37 pm
chris all the different ones i've dealt with have a mount each side and one in the middle.Whats the x member off?
Building a hardcore postie:D
Chris_Rogers
Post by Chris_Rogers » Sat Mar 24, 2007 7:55 pm
89 fwd sedan. the xmemember will bolt to a 3at 4wd (did it at the yard.)
crawled under a few later liberty wagons and they looked different. rear output area looked the same but these looked one piece from below.
if I use the xmember I have the mounts sit off the flat area. (yet to look at mount holes.)
looking for an easy option here.
thoughts
Audio Express
stamp_licker
Post by stamp_licker » Sat Mar 24, 2007 8:14 pm
the 3at x members and mounts i've got are 3 pieces like the tt mounts but not the same.from what i've heard if you grab the wrx or tt mounts ,you can add some plate to the original l xmember and reddrill the holes.I've fabbed up a complete new x member but it wouldn't fit in with your theme.Still reckon i could get a l or x member and tt or wrx mounts to work if needed.
Chris_Rogers
Post by Chris_Rogers » Sat Mar 24, 2007 8:27 pm
ok that makes sense. there was a RS version there sans engine so I'll look at that one.
rest of it is fine the Xmember lines up with the box so its just a bit of fiddling now.
wouldnt mind crawling under yours at some stage as well.
Audio Express
stamp_licker
Post by stamp_licker » Sat Mar 24, 2007 8:43 pm
give us a call sometime.Stiil got my number?
Chris_Rogers
Post by Chris_Rogers » Sat Mar 24, 2007 8:49 pm
chuck it in a pm. probably do but to be safe..
Audio Express
