Compression/oil prob ej22
- stamp_licker
just done a compression test,i've got 170 in 1 ,170 in 2,195 in 3,150 in 4 dry test.Wet test 170 in1,180 in 2,195 in 3,160 in 4.The motor is using a bit of oil about 1L in about 1300km.What the go?apart from that it seems to run fine.
Building a hardcore postie:D
- waggaclint
- Brumby Boy
if its using oil id say its you rings or valve stem seals
RIP 1992 Brumby
RIP 1992 Brumby
- Suby Wan Kenobi
- stamp_licker
Is it worth doing?Suby Wan Kenobi wrote:You will have clagged up rings which mean you will have to pull pistons and remove the varnish by hand then replace the rings. Since the motor is that far apart overhaul the heads replace seals and its all good or another 300000kms
- Suby Wan Kenobi
