MY's, L's and EJ mounting differences
Posted: Wed May 30, 2007 12:38 pm
I recall reading that to fit an EJ into an MY is easier than an L ( or vice versa?) when it comes to engine mounts on the crossmember due to the plane or angle of things.
Q. does this mean there IS a difference between MY and L engine xmembers angles ?
If this is so it might explain my angle problems when fitting the L series 5 speed into my brumby.
Q have people also experienced the angle thing when fitting EA82's into MY/Brumby then ?
i am thinking this as i am asking self if i should rebuild my current EA81/5 speed gearbox crossmember to release all its stresses first before fitting my EA82T ( i modded the EA81 crossmember to take the L series 5 speed and when fitted it took some considerable force to locate things, ended up with re angled engine (fixed that with the stabiliser adjuster, now got NVH BAD ! )
haaaaa, got that all out...
