flywheel machining when renewing clutch?
Hey all,
putting in a new clutch on the weekend, as my brumby is almost undrivable with the amount it's slipping now.
So I'm wondering about flywheel machining. I've been told you should get it machined when you put a new clutch in... how important is this? (if at all)
Thanks as always,
tommo.
Thanks as always,
tommo.
we just put a new clutch in my car. The clutch dude recommended that i get the flywheel machined, it gives the clutch disc abit more "bite". I didnt get it done because the flywheel has had the holes reamed out and loctite'd to the motor(ej22). Seems fine now, absolutely zero slip
if u ever want to claim warranty on the clutch you will have to machine the flywheel
besides that i have put 3 clutchs in 3 different cars and never machined the flywheel
but would recomend u get it machined
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
have a look at the flywheel, if its got any hotspots, grooves or an uneven surface, get it on the mill. small surface cracks are generally ok. as others have said, warranty is void if you cant produce an invoice for machining, but if, like me, youve ever tried to claim a clutch on warranty, its just about impossible. i own a workshop and ive never had a clutch replaced, even after many attempts, machined or not.
- Suby Wan Kenobi
I had an EJ22 in previous Liberty - replaced the clutch, I didnt get it machined because it wasn't recommended by Subaru mechanic, he said you can machine its up to me, if the clutch was metal to metal then yes, but I had a little beef left on it when it was slipping - it was fine. This Liberty I have now has warped flywheel (the clutch shudders before catching) and its annoying but I got used to it - when it goes I'll get it machined.
Thanks for the feedback.
I found a mobile machinist today who'll come out on saturday, so I guess it's probably for the best. $60 he's charging, seems pretty reasonable to me.
Any other tips or things to watch out for when changing clutch?
I know about torqueing the bolts in the right order... that's all I've heard to be careful of though.
Tommo.
Tommo.
Thats reasonable considering he's got to drive out to you. I just got some Lib front brake discs machined (both sides) and that was $30 per disc. I brought them in to a brake place myself tho.
Nah you don't, thats the slow way...
You do the pressure plate bolts up tight enough to hold the clutch (close to the centre as you can get it by eye). The put the gearbox on, the shaft will allign the clutch itself. Then you can do up each of the pressure plate bolts one by one by accessing them through where the starter motor goes.
Don't know if this is possible on any other car but it works a treat on a suby!
This wouldn't be advisable in a 600hp race motor situation but is perfect in this case.
should be easy to do without the alignment tool neway but thelast time i saw an alignment tool was round 50 from repcos..but this is in Perth
aparently the g/boxes are easy to take out on these old subis, accordin to my boss neway who use to work on them when he was doin his apprenticeship
neways good luck with the clutch
Wagon is no longer....
- SUBYDAZZ
Last time I did a clutch I used an old input shaft BYB01 gave me. This time I didn't have one so by the time I had the box out I decided that spending $25 on a tool to align it to ease replacement was well worth the money. The one I got wasn't suitable (as I discovered when I went to use it) as it didn't have a small enough fitting (several in kit) to go into my spigot bearing so I had to backyard it by wrapping some electrical tape around the thread where the fittings did go. Worked a treat.
BTW I pay $22 per brake disc for machining and $44 for the flywheel (stepped or flat) at my local Brake & Clutch place - for comparison.
SUBYDAZZ
