Clutch Job - Remove Engine or Gearbox?
- SUBYDAZZ
Well It has been a while for me (not long enough) but I am still considering removing the gearbox (again) in my Liberty to facilitate replacing the clutch (AWD box).
It will be a backyard job of course so I have no hoist (car or engine), no block & tackle and no transmission jack.
For those who have done it either way or both, your opinions will be appreciated.
For those who have done the engine option, can two average people lift an EJ22 out of the bay without too many hassles?
What do you reckon?
What do you reckon?
SUBYDAZZ
- Brumby Boy
Drop the gearbox, so much easier, especialy if you have a hoist like i have access too lol
RIP 1992 Brumby
RIP 1992 Brumby
If you have an hoist - so much easier is to remove the engine & gearbox at the same time.
If you don't have access to the hoist, then remove the gearbox from under the car while on stands (up-to 600mm high would be good enough) and make yourself an gearbox tray/jack that would be able to remove gearbox.
I've done this on Subaru AWD twice, manual VN Commodore (removed engine & transmission at same time) Toyota Corona (under the car) Holden Camira (funny that you dont need to remove gearbox/engine as it has special shaft that enables to to change clutch)
If I was gonna do clutch job - I'd remove engine & gearbox at the same time - quicker and saves time.
- Outback bloke
Engine out is way easier. Hire an engine lifter if you don't have one. They cost about $35 a day. You could have the job done in about an hour and a half to two hours.
You don't even have to take every thing off the motor. Just take the radiator out, lift the motor and slide it forwards. You can get about 5-6 inches of room which is enough to remove/refit the clutch and get a clutch aligner in there.
- Outback bloke
