Lower diff ratios - auto transmission
- vincentvega
With all the current work being done on lowering diff ratios and low range gearsets in manual boxes, I have started thinking about modifying my auto. I currently i have an EJ22 lib with a 4.11 AWD auto. The rear diff is an open 4.11.
I have access to a dead 4.444 turbo box for parts, and 4.444 viscous diffs are easy to come by. What i dont know is how much work is involved in fitting the 4.444 crown into my 4.11 box?
Currently i run 26" road tyres (6% speedo error) and 27.5" offroad tyres (10% error). If i understand this right, changing to 4.444 diffs will give me a 7.5% gearing reduction, and will mean that i can pretty much drive to the speedo regardless of which tyres im running.
What do you guys think? Worth doing? Am i likely to notice the difference in gearing? The car currently feels a bit over geared around town, and it cant hurt offroad either.
Dane,
It is very doable BUT you will need to pull the front of the auto to bits.
PM me & will tell you more...
http://www.subiparts.com.au
0438 887 746
0438 887 746
- Suby Wan Kenobi
- steve_rising_sun
- vincentvega
There is the speedo driven & drive gears.
The drive gear is on the drivers side of the diff - on the output shaft inside the box. If you undo the cover around the drivers side out put shaft & look in you will see the gear. This then faces to the drive gear which gives you your speedo read out. The ratios are the same for 4.111 to 4.444.
As the 4.444 boxes ran a 15" rim but had the same rolling diameter as the 14"
0438 887 746
0438 887 746
- Outback bloke
- steve_rising_sun
Guest
- steve_rising_sun
