Hi all , my RX has lunched its nearside CV joint and I'm not sure what I'm being offered is the right thing .
Its being supplied complete for ~ $230 and while the inner joint is 25 spline the shaft only has 2 rings and unless I'm blind the CV does not look new .
The hub nut threads look slightly different adjacent the split pin holes as if a nut had picked up and flattened the tips of the threads .
Anyhow my manual shows the two ring shaft as being an "87AC" which equates to 1800 MPFI 2WD in RHD cars . Its supposed to be 257mm (10.12") between the inner boot clamps where the 3 ring shaft or "95AC25" is 242mm (9.53") .
I just want to know where in Sydney do I go to get the right thing for an 8/86RX turbo manual .
Thanks all , cheers A .
Trying to get RX Turbo Manual shaft and joints ...
- discopotato03
- Suby Wan Kenobi
- Suby Wan Kenobi
