Cam Shaft removal questions
Posted: Sat Jul 14, 2007 11:53 am
by Matt
What is the easiest way to remove the camshaft and followers on a EA81?
Can you replace the cam without pulling the pistion out?
Do i need a waterpump gasket kit?
Does anyone have any pics of an EA81 pulled down? Where the cam sits etc?
Hopefully early next week i will be putting in my Dual Port heads, Modifed Cam, Solid lifters and new push rods! And just want to make sure i have everything i need, so i don't have to wait for parts. So far i have VRS kit, rear main seal, oil filter, oil, coolant and my new intake manifold and gaskets, should that cover it?
Thanks
Matty
Posted: Sat Jul 14, 2007 5:21 pm
by Suby Wan Kenobi
Ea81 Cam comes out from the rear of the engine it sits above the crank you have to pull the motor and remove the flywheel to get to it
Posted: Sun Jul 15, 2007 12:04 am
by 90brumby
ill take some pics 4 ya 2morrow i think u may need to split the block tho
could b wrong on that
Posted: Sun Jul 15, 2007 10:22 am
by Matt
Thanks for the responses so far, i figured you might have to split the block. Pics would be awesome Tristan.
Posted: Sun Jul 15, 2007 11:18 am
I have not tried SWK's method of pulling it out from the back, but it sounds do-able as that is how some cams go in and out of position anyway, a better short cut to seperating the two block halves, which I guess you could do without piston removal. To split block also need oil pump removal and sump gasket
Posted: Mon Jul 16, 2007 3:00 pm
I thought i read somewhere that you need to split the block to change the lifters in the EA81... i thought this was a silly design and wondered if its actually true.
Posted: Mon Jul 16, 2007 5:05 pm
by Matt
I will post up pics when i do mine, however some before hand would be nice.... if someone has some.... Hopefully tomorrow it all arrives.
Posted: Mon Jul 16, 2007 6:46 pm
by Brumby Boy
Hay man dont forget to give me a yell if you need a hand, im more than willing...
Posted: Mon Jul 16, 2007 7:05 pm
by Matt
I will have a play, and see how i go....Also i a have a few house mates that owe me a few favours for some certain engine conversions, so get it out and pieces shouldn't be to much of a drama. Another couple of questions
1. I assume so, but is the Cam marked at 0 Degrees or TDC? Same for distributor?
2. I would assume if i have to take the pistons out of the bores, they will slide back in?
Thanks
Matty
Posted: Mon Jul 16, 2007 7:11 pm
by Matatak
Matt wrote:I will have a play, and see how i go....Also i a have a few house mates that owe me a few favours for some certain engine conversions, so get it out and pieces shouldn't be to much of a drama. Another couple of questions
Thanks
Matty
1. not sure if dissy is marked but some are otherwise just put a line in with wihitout or somethign for the way it should be facing (dont put it on the metal fo the rotor tho)
2. pistons wont slide straight back in as the rings will eb in the way but they will go back in with a piston ring compressor.
Posted: Mon Jul 16, 2007 8:31 pm
by Matt
Matatak, the marking of the distributor will only work if the timing doesn't change which it could if i have to split the block and reset the cam.
Thanks
Matty
Posted: Mon Jul 16, 2007 8:55 pm
by Matatak
but everthting else should be marked for a TDC position but sometimes the dizzy arent so u mark them and get them back in exactly how it came out when eerything was on TDC and it will work without guessing which way the rotor was facing when the dizzy came out
Posted: Mon Jul 16, 2007 9:42 pm
by Matt
Sorry mate i was thinking the wrong way about it, got in my head now..
Posted: Mon Jul 16, 2007 9:57 pm
dizzy has marks and so do crank/cam cogs for reassembly.
I think lifters fall out of head if you tip em, so block not need to be split for changing lifters
Posted: Mon Jul 16, 2007 11:42 pm
by 90brumby
ok had a look at the engine out the bak
u ave to pull atleast 1 head off as there is a bolt behind it to split the block
yes u ave to split the block n then pull the cam out n then the foloweres
i will try n get the pics up but it didnt wrk b4
Posted: Tue Jul 17, 2007 5:39 pm
by Matt
PM Sent 90brumby, send the pics to my email and i will post them up.
Posted: Tue Jul 17, 2007 8:08 pm
by 90brumby
[ATTACH]276[/ATTACH]
[ATTACH]277[/ATTACH]
the engine was stripeed to take the cam n folowers out
Posted: Tue Jul 17, 2007 8:13 pm
by 90brumby
can take more let me no if u want em
Posted: Tue Jul 17, 2007 10:02 pm
by Matt
Thanks alot for that, if you could do a pic from the other side and maybe top and bottom, if it isn't to much drama.
Matty
Posted: Tue Jul 17, 2007 10:12 pm
by 90brumby
yer thats fine it will b 2morrow now theres no lights out side
