Iv'e been told that I can find all the info I need here.
I am trying to find out if there is a way to get 4.11 or 4.44 gears into a 5spd Dual range EA82 gear box.
Looking for 4.11 or 4.44
4.11 Box
Not an option for EA 82 box unless you build up a Liberty(Legacy) dual range in the L series case. You can then use the 4.11 or 4.44 R & P with the gearset from the 3.9 dual range box. You will need the viscouse centre diff so a shorter tailshaft and modded gearbox mt. Basically a complete rebuild with all gears swapped over.
