4spd DR box - Seal at front?
Posted: Mon Sep 10, 2007 3:17 pm
by Matatak
can anyone tell me if there is a seal or something at the front of the 4sd DR manual boxes found in MYs that can leak oil into the bell housing??
just pulled mine off the engine and had a fair bit of oil around the bell housing with some sitting down the bottom.....but there wasnt any to be found over the clutch.
the rear main on the engine is definetely leaking also but i need to no aobut the boxes and if oil can be coming outta them into the bell housing as i dont want to put it onto the EJ if its gonna leak out and possibly screw my clutch up
Posted: Mon Sep 10, 2007 3:47 pm
by Matatak
so i just read something that mentioned there is a seal at the front but the box wuld need to be split to get to it...any truth in this
all i can see at the front is a plate with 3 bolts in it that kinda seems like almost a bearing for the input shaft and holdin it up in the right position
Posted: Mon Sep 10, 2007 4:19 pm
think the seal is inside and the first thing you install on a put it all back together sort of deal from what i remember being told . Good time to do a conversion if time and money available
Posted: Mon Sep 10, 2007 4:27 pm
by Matatak
noooooo :(
cant do the box conversion right now as tima and money are not available. (and parts)
guess ill be leavin that one then who knows maybe it is only the rear main frmo the old motor thats got oil in there (rear main had so much movement in it its not funny)
Posted: Mon Sep 10, 2007 4:32 pm
by Matt
It more then like just the rear main on the engine, as the front main on the gearbox is actually above the oil level thus it only can like when you are dring down hills....
Posted: Mon Sep 10, 2007 4:33 pm
by FROG
youd smell gearbox oil!!!
Posted: Mon Sep 10, 2007 4:52 pm
by Matatak
ahhhh tru Matt thats good info :) (altho i ave been down some nice hills in it while offroad but mostly up :p)
yer i wudlnt of thught it was box oil neway due to the color of the crap and the smell lol
