L Series 3sp auto band adjust ????
Posted: Wed Oct 10, 2007 12:55 am
does anyone know exactly where to find the band adjustment on L series 3 speed auto, and can describe in words for me. I have manuals but it ain't clear which 1/4 square plug is the adjuster. I do have a inch pound torque wrench and the specs of 9in/lbs (think) and back off two turns, but WHERE ???
ta
Posted: Thu Oct 11, 2007 10:03 am
think I have found it.
filters in these ? can't tell from diagrams, maybe time to open here up from underneath
Posted: Thu Oct 11, 2007 8:12 pm
by Suby Wan Kenobi
Only filter is in the pan
Posted: Fri Oct 12, 2007 12:34 am
that's what the diagram looks like but not listed in pic nor mentioned in service procedure of what I have read. still had some fun in her today, be nice to see if i can make it behave a little better with a service
Posted: Fri Oct 12, 2007 10:06 pm
by Suby Wan Kenobi
You can go into Subaru and ask for the filter for the series 1 liberty autos. its a kit for about $20 with filter and lines.
Posted: Sun Oct 14, 2007 3:39 pm
'sus that is reasonable, ta
they'll do the tree speed autos?
Posted: Sun Oct 14, 2007 7:18 pm
by Suby Wan Kenobi
They are an inline filter retro fit to the first series AWD autos so to fit to a 3 speed auto do the same as instructions and tap into the fluid line to the radiator and find a suitable mounting spot.
Posted: Tue Oct 16, 2007 11:50 pm
OK , ta. Finally found some service notes, still not clear as to replace the drain mesh. It is actually running quite well now without me fiddling. I just need to back off a bit on accelerating to get it to change up. On slight power it will shift to 2 , then top with no trouble Brakes well on held gears down hill and mountains too.
Posted: Tue Oct 16, 2007 11:55 pm
by Matatak
are these trasnnys different to most normal ones?
most these days that i work on all have a filter inside the Pan than can only be got to by taking the pan off
some have one outside liek an oil filter cartridge style (my lancer does)
its only some Psteering lines which had a Filter in the lines i thught
Posted: Wed Oct 17, 2007 8:24 pm
by Suby Wan Kenobi
Sounds like your valve body needs a clean out
Posted: Wed Oct 17, 2007 11:59 pm
it is getting better as i drive it (done 600km in the week) but can still hang on to 2nd. Valve body brings back memories of this red hydraulic oil dripping everywhere from above and going up me sleeves and all over the place. Think a nulon treatment might be in orde to soften seals up
Found me torque converter to flex plate bolts came loose coz i no use thread locker - started to make a ting ting noise
Posted: Thu Oct 18, 2007 12:08 am
by Matatak
steptoe wrote:it is getting better as i drive it (done 600km in the week) but can still hang on to 2nd. Valve body brings back memories of this red hydraulic oil dripping everywhere from above and going up me sleeves and all over the place. Think a nulon treatment might be in orde to soften seals up
lol dont normally need locker on the torque converter bolts.
did u end up finding the band adjustment? did it do anything if u "adjusted it up"?
