I think my engine is ****ed..help
Post by D3V1L » Sat Nov 10, 2007 1:43 pm
96 rex, runs or DID run very very well
this morning i started it up and theres metallic grinding knocking and all sorts i the motor...sound like a big end bearing or similar??
opinions please...i think im up for some megga repairs now :( that hurts
dave
Matatak
Post by Matatak » Sat Nov 10, 2007 1:55 pm
is it still running on 4?
sounds like u culd be up for a bottom end rebuild.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Nov 10, 2007 1:56 pm
If it sounds like a big end it generally is. It will more than likely be number 4 big end if thats what it is. Just do a check around the engine to make sure you havent picked up something by driving over it and also check to see the it isnt an idler roller in the cam belt area.
The long road ahead
Post by D3V1L » Sat Nov 10, 2007 2:35 pm
alright..bad news is it just threw a rod....BIG TIME.....no longer runs....now im in the **** :(
Matatak
Post by Matatak » Sat Nov 10, 2007 2:39 pm
do any serious damage? as in parts coming outta the block?
time to go forged internals so it dont happen again.
Post by D3V1L » Sat Nov 10, 2007 2:43 pm
is anybody willing to lend me some space so i can pull my engine out and let the car sit there?? i have no space at home and i NEED to get my car back on the road ASAP
please help :'(
dave
Post by D3V1L » Sat Nov 10, 2007 2:50 pm
i am going to need help as im gonna rebuild this engine myself....hopefully..
Post by AndrewT » Sat Nov 10, 2007 5:43 pm
U can put the car at my place if you want. Engine hoist & tools are there.
90brumby
Post by 90brumby » Sun Nov 11, 2007 12:29 am
i believe we are gonna tow the car to my place pull the engine out then tow it back to his house i could b wrong only time will tell how much damage has been done
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Nov 11, 2007 12:35 am
If its thrown a rod the crank journal may be in need of serious work but i would check really well so see if it hasnt tried to poke out through the block. I knows that if you really want to know the engine in your car you should always fix the engine that you have but you may find it a cheaper and more convienient alternative to just put in a second hand engine from a wreckers and then if need be rebuild your original motor. That way should you want to you can put in the best bits your money can buy
The long road ahead
Post by D3V1L » Sun Nov 11, 2007 10:19 am
thats the plan...rex now resided under the car cover in the driveway....will be towed to tristans house today and rip motor out...and the fun begins...its just a ***** caus its my only car atm and im out of money completely :(
**** happens i suppose
gonna buld a bulleit proof motor out of this one....so it never happens again
dave
Post by Alex » Sun Nov 11, 2007 10:25 am
bad news boi, let me know if ya need a hand ;)
Post by D3V1L » Tue Nov 13, 2007 12:04 am
OK guys..the engine is apart and all diagnosed
lot less damage then origionally thought
2 x big end bearings are ****ed
2 x little end bearings are ****ed
due to this small issue the engine appeared to be totalled :P
SO where do we go from here??
ill put up a rebuild thread tomrow from start to finish and im gonna start the massive rebuild i hgave ahead of me
im prolly gonna go forged internals every seal the works....refresh the whole engine and give it a good life expectancy from here on end
tomrrow ill put up the start....and pics of the tear down and damaged parts
dave
littlewhiteute
Post by littlewhiteute » Tue Nov 13, 2007 6:23 am
Are the damaged bearings at the same end of the motor, ie: 1 & 2 (or 3 & 4)?
Maybe an oil supply issue?
Gary ;)
Post by D3V1L » Tue Nov 13, 2007 7:54 am
nup the big ends where 2 and 4 and little ends where 3 and 4...it was possibly an oil issue but highly doubtfull
Outback bloke
Post by Outback bloke » Tue Nov 13, 2007 3:44 pm
How bullet proof do you want it? I can give you a contact, although it is here in Qld, to make the block the same as my 2.5. Capable of 25psi all day every day. Diesel liners, closed deck, forgies, tension bore etc. Cost me $2500 just for the block and bottom end plus another $900 for pistons.
Post by D3V1L » Tue Nov 13, 2007 4:30 pm
cheers for the offer :D
but i already have contacts here that will do it cheap cheap ;)
forgies in the form of cosworth pistons and rods will cost me $1200 anmd the block work will cost me around $1400 odd....all thanx to a very good mate and his very good mate :D capable of 30 pounds all day every day :D
dave
BrennyV
Post by BrennyV » Tue Nov 13, 2007 4:55 pm
i herd there is some one who got masters made of cossy bits in perth ;)
Hunter S. Thompson
Post by D3V1L » Tue Nov 13, 2007 5:35 pm
ive heard that too ;) dont u worry my ears have been open :D
Post by D3V1L » Wed Nov 14, 2007 3:33 pm
alright guys the total damage bill has come in
2 x crank rods are cracked
all the big end bearings
all the little end bearings
BENT crank shaft (60 thou)
possibly a bend in the block but hopefully not
looks like im up for a megga rebulid, and as of this point i wont be doing the bottom end..its now at a mate of mines shop and he will redo the bottom end for me and ill finish off the top end and all the add ons
got hold of some cosworth forged pistons for $1380 today they are going in
