maximum flywheel clutch-depth...
Posted: Sat Jan 12, 2008 12:33 pm
Hello all, well clutch was slipping in the Vortex I bought, so we've pulled it out and the clutch and pressure plate look okay (yes, the cable was adjusted correctly), Fly wheel has been machined in the past, so I am wondering if it had been cut past the max. operating depth? Gregory's book tells bugger-all, so I wondered if someone on here had the specs for the standard or max. flywheel depth for EA82, or even if you have one in the shed if you could vernier it....would be excellent!
Cheers, Neville.
Cheers, Neville.
