EA82 carbie fuel pump control module
Because the EJ22 ECU still refuses to switch the fuel pump, I'm trying to use the original L Series fuel pump control box. It switches on with the ignition, but then cuts off after a few seconds, presumably because it isn't getting an "engine running" signal from the EA82 wiring (which is now all rolled up and tucked away inside a mudguard).
Anyone know what this module uses to work out that the engine is running, and where I can find it? Hoping it's as simple as powering or grounding one wire, or else the car might just develop a fuel leak and a stray spark.
Dane.
Dane.
- TOONGA
it is from the mythical L series FSM that T'subaru owns. I know in my brumby the relay is behind the passenger seat be hind the plastic that hides the shell of the car (if that makes any sense)
the jpeg comes from this thread
showthread.php?t=18159
Yep, I know where the fuel pump relay is (under the dash on my car, up above the driver's side kick panel), the hard part is finding the wire I need to make it see that the engine is running. You mentioned distributor - that's probably what I'm looking for.
Dane.
Dane.
- TOONGA
I reallise now that the mpfi 89 Lseries ecu is no good for a carby engined car the gregorys manual showthread.php?p=150909#post150909 (if you don't have a hard copy) section 17.2 has the wiring diagrams for the L series carby motor
dizzy or coil? We use a coil reading to tell things engine is now running in LPG stuff called a tachometric relay and it is what you could use quite easily and cheaply. They are about $30 or less, provide a primer power supply for starting and will cut out after about three seconds if coil connection does not signal it engine is cranking or running.
Peel instruments in SA have a website a bit like peelinstruments.com.au ?
Bingosteptoe wrote:dizzy or coil? We use a coil reading to tell things engine is now running in LPG stuff called a tachometric relay and it is what you could use quite easily and cheaply. They are about $30 or less, provide a primer power supply for starting and will cut out after about three seconds if coil connection does not signal it engine is cranking or running.
Like Jonno says.. it runs off the coil.. when the dizzy starts spinning (and pulsing) the fuel pump relay jumps in.. both Carby and EFI models have the priming circuit (about 5 secs) You'll need to find the wire from the negative side of the coil (also the same for the Tacho) and then grab a negative trigger from your Ignitor
Reckon the that's in the car already must be very closely related to a tachometric relay.
Anyhow, I ended up doing a quick and dirty fix with the pumps switched straight off the ignition. Not perfect, but got the car running for the first time in months. Thanks for the tips fellas.
Dane.
Dane.
Just for future reference, others that my read this post. Dane's (GOD) car was originally a Carby EA82 and has swapped the engine for a EJ22 (EFI)
BTW.. how's the top end Dane?
Didn't see those last replies. Thanks Paul, that's exactly what I was after. But I suspect my temporary fix is going to remain there for some time - just drove the Subie out of the garage to make room for the "good" car that now needs work
Dane.
Dane.
No probs bud.. pics of the "good" car.. better be a Suby
Yeah, what he said.RSR 555 wrote:Just for future reference, others that my read this post. Dane's (GOD) car was originally a Carby EA82 and has swapped the engine for a EJ22 (EFI)
Yeah pretty good. Lots of places to explore. It's tough on cars though - seven flat tyres in less than six months, and assorted minor damage.BTW.. how's the top end Dane?
Dane.
Ummm... it's white, it's Jap, it's four wheel drive, it has four cylinders and a turbo, and it's hard to get parts for up here. So it's just like a SubieRSR 555 wrote:No probs bud.. pics of the "good" car.. better be a Suby
Dane.
As long as it's Toyota and Diesel then I'll forgive youGOD wrote:Ummm... it's white, it's Jap, it's four wheel drive, it has four cylinders and a turbo, and it's hard to get parts for up here. So it's just like a Subie
Dane.
