Pls Critique Cooling Fan Wiring Diagram
Smokey
Post by Smokey » Sat Jul 26, 2014 2:19 pm
Hello fellow Soobi fans. Been too long since I've had time to play with my car let alone do some posts :(
I'm putting in manual controlled thermo fans, twin relays and an 1/off/2 dash switch, no auto.
How does the below diagram look? LED was an afterthought. At first I though an illuminated switch but there are not many out there small enough to fit in the cluster above the headlight (S1) switch on the L (same place inside air etc is located).
Post by steptoe » Sat Jul 26, 2014 5:45 pm
critical Jonno, sharing what I found to be easier than inline fuses - Jayacr at least sell relays with a fuse socket in the front so incoming power through pin 30 goes via the fuse. Easy to find and check if and when need arises
Post by Gannon » Sat Jul 26, 2014 6:24 pm
Looks fine, but why no auto control?
Smokey
Post by Smokey » Tue Jul 29, 2014 1:59 pm
steptoe wrote:...relays with a fuse socket in the front so incoming power through pin 30 goes via the fuse...
Thx for the heads up Jono, see this thread for a rough diagram of my drivers side fuse panel (inc fuses), relays will sit just a few cm away. Needless I do have one of these fused relays that I do a bit of testing with.
Gannon wrote:Looks fine, but why no auto control?
To be honest Gannon, I probably should. I lacked an understanding of wiring in the early year and a few years with a bad radiator have lead to me like watching engine temp. I have an aftermarket temp gauge that shows actual incremental temperature so I can control fans in real time.
The only reason I'd now add an auto setting is for when someone else drives my car. Peace of minds sake. Not sure how I can wire that into my current setup.
Few new pics of where its up to. Essentially a labelled pigtail ready to be installed.
Post by steptoe » Tue Jul 29, 2014 7:23 pm
think it is smart having both fans whoop it up at same time - no mucking around, BUT I also find it handy in some situations just to have one fan on (and forget its on :( )
I reckon next Brumby will get the fans, or maybe one, come on in conjunction with the brake lights - you know, sitting in traffic, foot is on brake a lot anyway - allows for mind to be in neutral and engine keep cool.
Neville fitted a TFS132 to his rad and fans come on at 85 off at 80. I fitted same part number, fans come on at 92 and off at 72 despite what tridon claim !!
Smokey
Post by Smokey » Fri Sep 19, 2014 3:34 pm
Discrete switch dash mounted. Led lights when either 1 or two fans powered.
LED is BRIGHT at night, some dull red paint might do the trick. Would not be so
bad were it mounted at a lower "out of face" location.
Relays, one per fan, separately fused from existing dist block. Just noticed I have
the 25A fuses still, need to drop that back to 15 each.
Thread complete.
Post by steptoe » Sat Sep 20, 2014 9:19 am
Colin, that fuse panel , is it a single input for all the blade fuses ? If so, it is a better alternative to the one I installed, and curious to klnow where you got it , brand, part number etc, save me making up my loops :) on the next project.
Those LEDs are more spot than flood hey ? 8) The reminder light is a good idea, may have to include these somewhere too, and despite my recent dramas from wire fiddling, still think I am going to use brake light switch to activate a fan - using a diode of course :)
Post by Gannon » Sat Sep 20, 2014 2:43 pm
Rough the outer surface of the LED with sandpaper, makes it like a frosted/opaque bulb and gives a scattered light output
Smokey
Post by Smokey » Mon Sep 22, 2014 3:49 pm
steptoe wrote:...is it a single input for all the blade fuses
Yep works quite well, I like things neat as I can to my ability. Ebay, search fuse block. This one is a Blade terminal, ring terminal under screws would have been better. This one is a 6 way. Some also have a ground bar, but I find that unnecessary in a chassis grounded vehicle. Think it was $24 ish.
I'm also really keen on these heat shrink connectors (though a little pricey).
(insert multi quote)...woops
Jaycar LED in Bezel so cant buff the surface unfortunately, though good thinking Gannon.
Post by steptoe » Mon Sep 22, 2014 4:04 pm
nice, thanks for the links
fuse size same as what is in L Series fuse blocks or next size down ?
I just use heatshrink 6.00mm over my connectors - black and red most commonly used, and never just plier crimp - either solder or utilux tool # 61 them. I am always pulling the plastic ferrule insulators off and dropping them about the place :)
Smokey
Post by Smokey » Tue Sep 23, 2014 3:46 pm
Yep standard blade fuses, same as under dash in the L series
FujiFan
Post by FujiFan » Tue Sep 23, 2014 7:44 pm
Those chromed LED bezels can be seperated easily, I used pull them apart to use my own preferred waterclear LED's as well as diffusing there output as per Gannon's suggestion. As for mentioning J@#$%r, I used to work at one so I wont make any specific endorsements.
J.
