wiring diagram for a 1992 brumby
Hi Everyone
I'M after a wiring diagram for the above
Also sometimes whilst driving the brumby shudders and slows down take foot off pedal and ok
is intermittent.
Drove it for todays in a row and runs perfectly got me stumped checked the usual stuff fuel spark leads etc
Cheers Tezbo
is intermittent.
Cheers Tezbo
- Bantum
Re: wiring diagram for a 1992 brumby
There are lots of places to find wiring diagrams : ( google search is a good as any place to start )
https://www.google.com/search?sca_esv=9 ... 68&dpr=1.1
& if you can get hold of a workshop manual, it will aslo have one. Can do a search for them as well ...
https://www.google.com/search?q=subaru+ ... client=img
As far as I know, the distributor has always been a weak link in the system, I would get it checked out for wear & tear - replace if necessary ...
Cheers, Bantum ...
Cheers, Bantum ...
I have found a copy of a Gregorys Manual #501 2wd & 4wd 1979-1994 Subaru Manual in .pdf format.Bantum wrote: ↑Sat Jan 11, 2025 2:50 amThere are lots of places to find wiring diagrams : ( google search is a good as any place to start )
As far as I know, the distributor has always been a weak link in the system, I would get it checked out for wear & tear - replace if necessary ...![]()
Cheers, Bantum ...
It says that is covers Sedan - Wagon - Coupe Oct 79 - 1994, Utility 1982 - 94. 1600 OHV - 1800 OHV - 1800 OHC except EFI & Turbo models.
http://wordpress.suberdave.com/ - Password: subaru
The one I looked at was the 3rd link down under EA81.
P.S. Came across some posts by El Freddo on the USMB website too.
Hmmm… I can’t remember posting about factory wiring diagrams on the USMB
Those Gregory manuals give you a basic idea of what’s going on. You might not be able to find an exact layout of the model year of your brumby. They should give you a general idea though.
Hopefully the links provided by Subyroo prove to be useful.
As for the driving cut out issue it could be a carb issue of some sort or an emissions gear issue with the vacuum hoses and diaphragms associated with it.
No twin, it’s definitely me - I just don’t remember posting about factory wiring looms on that forum…
