were is my power going
would twin 10" thermo fans/vl fuel pump constantly on be enough to prevent a battery from charging?
i seem to be running on minimal power any advise on were to look would be a great help.
head lights are dim, dash warning lights (been on since ea was ripped out) pulse and the power windows have little to no power
- Captain Obvious
i would be looking into alternator, maybe connections or its dieing a slow death!!!
removed that one wire still starts seems to be fine, i sure will know tommorow morning when it comes time to go to work.
so in my head the normal L loom shouldn't be sucking power,with the ej loom "main power" being supplyed by the "on" position on the ign switch and the back up memory the only new addition to the car with constant power. and the one unknown wire now removed i think it should all be fine.
will post yah or nah tommorow...fingers crossed
started today
in the morning, at lunch and after work.
the sparky removed the wire for easy cold starts (from the ecu to the starter wiring) but i think puting it back would help things aswell as a temp switch for the thermos, so two thermos arn't going when i'm trying to start it first thing in the morning.
im thinking two thermo fans kicking straight on ,fuel pump and a cold engine would make it quite easy to drain the battery whilst the ecu had been hard wired over night.
i think it should be fine now, im going to pick up a temp switch for the fans tommorow
