Oil Pressure Sender difference between Vortex and L Series
Is there one?
I need to get an Oil Pressure sender that is for the gague type (not the light). I have heard you can use a Vortex oil pressure sender. Can anyone confirm this? My motor is an EA82.
- Fury
Just got back, had a look and it's still on the engine block. It looks ok, ( via torch light) but I will remove it and double check it for you in the morning.
Chris
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT!
