BAC Valve error code
LongtimeAddict
Post by LongtimeAddict » Thu Sep 25, 2008 8:30 pm
Please help guys i'm desperate, going on holidays on Saturday and my ej22 conversion has gone belly up.
Finally got the car running, driving nicely, and suddenly its coughs n splutters then stalls. did it a couple of times so came home and checked the codes and its 24 - BAC valve & 21 Temp curcuit ( haven't wired in the temp gauge yet )
Checked resistance terminals 1 & 3 back to ecu - fine.
Power to terminal 2 12 volts.
voltage at ecu pin B1 7 volts.
voltage at ecu pin B2 7 volts, book says B2 should be 9 volts.
Resistance between terminals on the valve 10ohms
Does the temp gauge affect operation of the BAC valve ??????
Any suggestions would be enormously appreciated :(:(:(
99 Outback (stock at the moment) :rolleyes:
LongtimeAddict
Post by LongtimeAddict » Fri Sep 26, 2008 3:25 pm
Bump !!! Anyone ? :(
stamp_licker
Post by stamp_licker » Fri Sep 26, 2008 5:32 pm
The temp sender that ecu gets it info from is not the same sender the temp gauge uses.Pretty sure it has nothing to do with the BAC.
Building a hardcore postie:D
LongtimeAddict
Post by LongtimeAddict » Fri Sep 26, 2008 6:17 pm
Thanks SL. It all just got way more complicated. no longer showing code 21 & 24 - started showing 23 & 24 MAF & BAC. Checked out the maf and all voltages etc are spot on. Disconnected the ECU, left it off for 10 mins and now not giving any codes :confused::confused::confused:
I'm beginning to think its the ECU itself. Has anyone had an ECU go? And if so what were the symptoms? Does anyone agree or disagree?
