1995 Liberty A/C failure
Having tested the pressure and temperature limit switches as OK. I checked out the control relays. The fan relay is energised when A/C button pressed but compressor relay is not. Measuring with a volt meter there is supply to the relay coil but no earth return. This earth return is there sometimes and then compressor starts. Usually A/C starts and gets to the point where the thermostat turns it off, later there will be momemary turn on and then nothing. Seems like a thermostat failure.
The manual I have is no real help in finding the thermostat. Can anybody tell me where it can be found?
- TOONGA
I can't tell you where it is but this should it is the aircon system from the service manual for the 95 liberty
http://rapidshare.com/files/343265312/A ... SYSTEM.rar
MSA5TCD95L5735 I think might be the section you want
Is there enough gas? sometimes people dont realise there is not enough gas in the system and causing it to stop working, you're better off to be on safe side is to take it to air conditioning mechanic. If you know what youre doing go ahead. But my advice is to go to the mechanic - less mucking around etc.
Has this had anything to do with the ambient temperature of the cabin? My wife's 94 Lib has perfect AC until it is left in the sun and the cabin temp is high. It runs for maybe 30 seconds, cuts out and doesn't work until the interior is cooled by opening the windows etc. Hot humid days when needed most it refuses to work at all, is this anything like your problem??
- TOONGA
not a problem I have the rest of the manual if you want it, I can upload it or put it on a disc and either drop it off the next time Im up that way or mail it to youdavmax wrote:Thanks Toonga. A comprehensive set of documents. I see thermostat is on top of the evaporator module. Great help.
or there is a link to the 92 manual which is basically the same thing
http://www.upload-drive.com/file/3123/G ... l-zip.html
there is no heater section though
it comes from here
showthread.php?t=7011
or this link for the 92 liberty manual
http://subaru.ath.cx/1992%20FSM/AUS/
or the parent directory has the gregorys manual for the 1979-1994 Subarus
