hid headlights
hid headlights
just wanna know peoples opinions on them
Im pretty sure the use of retrofitted HID lamps in fittings not designed for them is illegal.
It is because HID lamps produce a different spread of light to filament lamps and the headlight lens must be designed to suit. Glare for oncoming traffic is the main concern
- Suby Wan Kenobi
Great they offer a superior white light but as mentioned by Suparoo you will need to adjust the light. Most HID conversions kits come with a a set of 3 globe adjusting screws, once the HID is fitted you adjust the 3 screws so the light spread is the same as the previously fitted globe. This can take some time to adjust of in other cases there is no adjustment required.
The long road ahead
The long road ahead
I did have the in my Liberty's projector headlights - it was worth it and the light output is unbelievable - in past 2 years since I fitted HIDs = I didnt get flash backs at all because I've aligned the headlights correctly. I did also fit them in normal Liberty headlights and was ok - light output was good, but it did scatter but didnt affect oncoming drivers.
No good for full beam since HIDs needs approx 6-10 seconds to "warm up" to boost full brightness. But you can buy H4 hi and low, (not HID low & halogen High as they're crap due incorrect bulb location)
- Green_eyed_liberty
