Leaking Headlight, indicator..
Posted: Sun Oct 09, 2011 10:00 pm
by guyph_01
Hi guys,
One of my side indicators from my quad light has accumulated rain water one night. Because they are the L sereis quad light and i can't easily get another one i was thinking if anyone know how to fix it?
I look at it and it doesn't seem to have any holes or cracks. So i'm guessing its the glue holding it together thats allowing water in. I know that you can put the glass headlights in the oven and this makes the glue melt so you can take it apart.
Do you guys think i can do the same thing with the plastic indicator?
Also at what temp and how long should i leave it in?
What glue should i use to put it back together?
Thx
Posted: Mon Oct 10, 2011 9:54 am
how about just make a feature of it - goldfish are cheap :)
Posted: Mon Oct 10, 2011 11:41 am
by Mr Top Hat
5000°c
Posted: Mon Oct 10, 2011 12:14 pm
Try pulling it out, clean the remaining water in it then try pushing/forcing silicone into the area that it's glued, go all the way around, let it cure then put it back in and see how it goes.
Posted: Mon Oct 10, 2011 1:18 pm
by RSR 555
Goldfish.. lol
I'd look at how so much water can makes it's way in there.. even if the light had a crack or hole, surely not that many rain drops would hit the right spot everytime :???: sounds like you've got a great water making machine hidden behind the light somewhere ;)
Posted: Mon Oct 10, 2011 2:18 pm
OK, if the goldfish idea not appreciated - howis the rubber boot at the back?
Gosh, Pauls reply reminds me , saw a pic of a Brumby with EJ conversion and auto with ECUs mounted on the top side of the under tray below steering column - if that is yours - get a raincoat just in case - cover from above
Posted: Mon Oct 10, 2011 7:56 pm
by d_generate
Drill a tiny hole in the bottom of the plastic at the lowest point, I fixed the tail lights on my young blokes Falcon years ago doing the same thing, dried up within a day and never had a problem after that.
Posted: Tue Oct 11, 2011 9:46 am
by RSR 555
No Jonno.. the goldfish bowl was a brillant idea and with Guyph's collection of animals, it would fit right in :)
I too have had that whole water leak on the ECU. It happened on my daugthers RX Leone. Gotta love Subaru for putting them there but I guess if the windscreen is in good nick then there shouldn't be an issue.
Tom's idea is good.. maybe a small hole in the rear case but that doesn't solve the problem of it getting in there :???:
Guyph.. have you tried searching or posting on USMB as these lights did come from there??
Posted: Tue Oct 11, 2011 3:18 pm
by d_generate
Nah, just solves the problem of it staying (^_^)
Posted: Tue Oct 11, 2011 10:25 pm
by NachaLuva
Have you washed the car with a high pressure hose? I got water in my headlight that way. Or maybe water splashing up from the wheel into the back?
I wouldnt put the plastic in the oven...too much risk of pulling out an ashtray!
I like the idea of the small drainage hole if you glue it back up when dry but as Paul says it doesnt solve how it got in there & if you dont fix that it'll just happen again.
If you want to run some glue around the join i'd suggest using plastic glue like from building those little models you did as a kid.
Hope you get it sussed...little things like that can be so frustrating!
