Yep, confused.
I am in need of xpert help on this one.
The LED 12V tester type you hook up to the battery first
, lights up both a green LED and a red LED until you touch the probe to either power
^^^^^^^believe it, this LED is red bfore digital photography got to it ^^^^^^
,or ground , if you got ground the red goes out
Uploaded with ImageShack.us
, green brighter? or if touch to power, green goes out and red brighter.
PROBLEM : is when I touch to what should be pos power out of my power adaptor down to 7.5 V the red LED dims! and green still lingers....
you know how a problem shared is a problem halved ? I may have worked it out - the output is set at 7.5 V , maybe if I shift it up to 9V or 12V if possible the green may go away
NOPE, not it...
story continues
Using a powertech voltage adaptor plugged unto a cig lighter attached to a small 12V sealed lead acid battery SLA
Testing the output of the adaptor firstly to determine polarity need pos to centre tip +
I have definitely got a bold green only LED on the outer of the plug
but when I touch the centre tip red LED dims rather than go brighter and green stays on.
I threw an Ohms resistance wheel
into things to see and depending on rating there the green LED glimmers or just goes out, leaving red to glow nicely.
Side note is if I use the old Subie lighter socket, I don't get a green operating light on the adaptor. Touch the battery direct to adaptor and yes green function light on
this glimmers or pulses when I have test lead on the pos tip too !!
Change power supply direct to battery does not solve problem either ??
Any genius's are welcome to comment
all in readiness to set up a battery powered cctv camera at an "outpost"
did someone say try a diode??
think there is one on a bench somewhere......
