Fiori park lights nighmare!!! help
Hi guys,
I'm having issues with this second fiori i'm trying to get back on the road.
When i turn the park light on, i hear a buzz and no, Front or rear park lights go on, neither does the dash lights or rear number plate lights turn on.
If i don't turn the park light on and turn the roof light on, I get the same buzzing.
I've replaced relays, the indication stalk multiple times and nothing! So now i think there might be an issue in the wiring...
Anyone have a wiring for the second series, 1992 model? Jules!!!! help....
Thx
Thx
- Bantum
Check list ...
It would appear to be a process of elimination to find the culprit by checking the following :
Cheers, Bantum ...
- All globes are working,
- Fuses intact / correctly rated,
- Relays function like it should,
- Switches in good order,
- Wiring in good condition ie: not shorted / corroded ...
Cheers, Bantum ...
If the relay is buzzing Id say you have a corroded, or crappy connection somewhere. Get a can of crc and some steel wool. The relay is buzzing because as the current comes into the relay to pull it shut, the voltage is dropping. The voltage is dropping because somewhere in the circuit is something with really high resistance and Ohms law takes over. The voltage drops so low that the relay throws back out. When that happens the voltage goes back up because the current goes away, so the relay tries to pull in again. It Does this over and over, hence the buzzing. Check the connections going to the relay, specifically the wires that come from the switch, to the relay. Chances are its actually the switch.
A quick way to test all this would be to short out the wires after the relay. All the park lights will come on. If that works short out the switch inside the cab. If the relay comes on and the lights come on its the switch.
Doug
Doug
Do you have a multimeter? Check the resistance across various sections of wiring esp across the controls & relays on the loom side of the connectors. My guess is you have a poor connection somewhere or possibly a wire shorting out somewhere in the loom, not the items you've replaced.
