Retarted Brumby...
- SoobiDoo97
Retarted Brumby...
ok guys, i have a 91 Brumby and its retarted! it doesn't have a hazard light switch anywhere... it does have a thing that you push behind the steering wheel but that turns on the right hand blinker only.... the choke switch also doesn't operate the choke, it controls the winscreen wipers....... its also has an alarm under the bonnet but it isnt set up.....
How can i fix these problems?
- Gone Fishing
- Silverbullet
Do the indicators work normally on both sides with the indicator stalk? I had a similar thing with the hazards only working on one side, turned out it had the wrong bulb in the light socket in the tail lamp.
what is retarted? you might mean retarded.
Suggest you put a photo up here and label the bits you are talking about so someone can confirm what they are supposed to do.
EZ30 L series - Monsterwagon
Mine is the same. When I got it only the RH indicators would blink, mechanic said he had to play around with the contacts in the ignition barrel to get it to work. Now it takes a few blinks of the right indicators for the left ones to come on, but as it's ultimately working I haven't touched it further. I guess I'm going to be up for a relay at some point.
