check your alternator for too many Volts ?
Post by steptoe » Mon Mar 10, 2014 6:08 pm
Thought I'd better follow up and check the alternator I dredged up to fit to my EA82M (M is for Mongrel)
Fuji me ! Starts at 14.1 Volts and as the revs build up - nowhere near my 6000 redline it went to 17, 18 Volts.
Seen this before with a flat battery in the multimeter, so used another, got same result. Checked another car with both DMM's and got normal result.
Swapped in another to save a fry up. need to research external voltage regulator. Jaycar used to do kits for smoother output ....
No hurt to check eh ? It's not just low output that can screw a good day !!
d_generate
Post by d_generate » Mon Mar 10, 2014 8:40 pm
Snap up a couple of these, I bought some about 6 months ago and they let you know how you're charging when driving and what's in the battery with just accessories on.
You can pick up 5 delivered for less than $15.
http://www.ebay.com.au/itm/12V-24V-LED- ... 1e87cfdf78
Post by RSR 555 » Mon Mar 10, 2014 10:13 pm
Sounds like you reg is shot
Post by RSR 555 » Mon Mar 10, 2014 10:14 pm
d_generate wrote:Snap up a couple of these, I bought some about 6 months ago and they let you know how you're charging when driving and what's in the battery with just accessories on.
I have one of these too. I use it to watch the battery drop on my camper trailer. Works well in the car when not on the trailer.
Post by steptoe » Tue Mar 11, 2014 7:37 am
I'd say reg is shot too :)
$2.95 is affordable permanent fixture, ta for the link
OK. What is it about accurate Volts checker needing another separate power source ?
My GLTA has a Volt monitor that I switch between battery and knock sensor - it needs its own power supply for reasons of accuracy especially when monitoring the 1.7 to 4.5 V of the knock circuit. I run a SLA in the glovebox for it
d_generate
Post by d_generate » Tue Mar 11, 2014 3:16 pm
I haven't fitted them yet but I also bought some of the flat square hard wired ones so I can see what my 330w solar panels on the Transit are chucking out and what's in my 320ah working batteries at a glance as the regulator is in a cupboard. They seem to top up to 13.1 even though I'm punching 14.7 into them most of the day.
They were even cheaper I think so one under the bonnet too.
Post by steptoe » Tue Mar 18, 2014 7:44 am
just ordered a pair to sample
Post by steptoe » Sat Mar 29, 2014 9:39 pm
just got 'em in 10 days. Does the job nicely :)
d_generate
Post by d_generate » Mon Mar 31, 2014 12:57 am
Pretty handy eh? especially at that price, gotta wonder how they do it.
Post by steptoe » Mon Mar 31, 2014 7:51 am
:) , maybe like the guy who walked out of a coin mint with a $100,000.00 in $2 coins - the good old lunchbox ! A few each day.....
Or nightshift at a multinational company that doesn't know about a night shift ......only the locals did
