factory turbo loom help needed
- chubby37
would anyone have or know of a link about the factory turbo wagon looms for an ea82t...i got my hands on a rhd factory touring wagon turbo loom and just want to check its all wired the right way..there looks to be a couple of plugs i need the change.
- tim_81coupe
The lower sensor is for exhaust temp. I think its there to check that the cat is operating at the correct temp. I have one in mine.
You wont need it, but what ECU you have?
BTW, have you downloaded the EA82 OEM manuals for the 4 plug ECU and diagrams from the "Downloads" module on this board. Its a not too bad guide, a bit generic, but not Aussie model specific.
This wont be to helpful if you have the 3 plug ECU.
- chubby37
oh and my life just gets better......
...the loom were it plugs into the colum is 6 pin but the plug from the colum is only 5.....once i connect the battery the dam headlights come on even without the key in 8O ???????on top of that the power windows dont work
.....i cant seem to work it out...it may be something simple but it,s gut me stuffed.......any ideas......thanks in advance for any help
Got those diagrams for ya
http://www.ultimatesubaru.net/photos/sh ... puser=6651
I will try to find some for the power windows
The problem with the colum 6 pin and 5 pin. do you mean the steering column plugs and connectors?
I hope it works out
I hope it works out
How many relays do you have mounted up near the fuse box?
If you've only got 2, then I had this problem almost 10years ago.
Best bet is to try to get the matching indicator stalk assembly.
Otherwise, you need to swap the pins of 2 of the headlight wires. I can't remember which 2 though.
The side-effect of this is that the indicators flash about twice as fast
Power windows should be a complete separate issue as its a plug in separate loom. look for a pink 3 pin plug with only 2 big wires in it near the driver's side kickpanel.
Check for permanent 12v on the White/black & ign 12v on the red/yellow
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
