L-Series VSS signal MPFI
Posted: Thu Sep 27, 2018 3:18 pm
by L-Rex
Hi all,
Does anyone have a wiring diagram showing the pinouts from the MPFI dash?
I'm looking to pick up the VSS signal from the reed switch...
Re: L-Series VSS signal MPFI
Posted: Sun Sep 30, 2018 9:48 pm
I'm using it and it works a treat.
Check out the EJ into L series thread in the conversions page, it's detailed in there. I'd link it here if I was on the computer, but I'm just returning from the bush
Posted: Tue Oct 02, 2018 7:26 am
by Gannon
Is there no attachment upload anymore?
According to my diagram, its the Yellow/red wire at the back of the instrument cluster. It is also at the black 21 pin plug under the dash (there are 3 big plugs grouped togerther, white, black and blue) on the body side of this plug it is Yellow/green and is also the Yellow/green wire at the "check connector" behind the drivers side strut tower
