4WD LO light stays on now...
maddog
Post by maddog » Thu Oct 05, 2006 6:24 pm
Hi All (Especially Suparoo!)
L series 4x4 wagon 1987, When I first bought this car 4 months ago,
I tried it in 4WD to check it all worked including LO ratio. They all worked
so I was happy. However, I don't think it had been in LO for a very long time and the LO light stayed on, maybe a hint that it wanted more LO range action for a change!!!! Anyway - now it's annoying me because I can't figure out how the LO range switch is activated or where it lives. My guess is that the actual switch is stuck ON. I've tried simply shoving it into and out of LO repeatedly but no change.
Any clues anyone? Thanks...
vincentvega
Post by vincentvega » Thu Oct 05, 2006 6:41 pm
it lives in the center console, under the hi/lo lever
its a microswitch, the metal lever will be bent. You should be able to jsut straighten it to adjust, worst case its a $5 part
KERAZY
Post by KERAZY » Fri Oct 06, 2006 3:26 am
ive got a similar problem in my MY, the 4wd light is always on. is that the same thing in regards to repairing it?
Post by steptoe » Fri Oct 06, 2006 11:36 am
my experience says vincentvega is correct...on MYs ,
Brumby 4WD selctor switch is at base of the lever near handbrake
L 5 spd d/r box have them on the box itself, can need cleaning or spacing with o ring or washer to get right again. cleaned with crc before
see technical manuals 5 spd into MY-- details where switches are on the 5 spd d/r box
or a wire could be earthing out somewhere too !
vincentvega
Post by vincentvega » Fri Oct 06, 2006 11:52 am
might have changed over the years, but i have definately adjusted a broken switch on 2 different L series...
Xtreme_RX
Post by Xtreme_RX » Fri Oct 06, 2006 1:48 pm
Vincentvega is correct.
The 'LO' switch is near the 4WD lever.
The liberty's run the switch on the 'LO' selector on the gearbox.
http://www.subiparts.com.au
0438 887 746
daza
Post by daza » Fri Oct 06, 2006 4:25 pm
in the "L" d/r box in my Brumby, the "4wd" switch is in the box and the "Lo" switch is on the shifter...
Daza.
:D
Post by steptoe » Sat Oct 07, 2006 11:00 am
lucky I said 'in my experience'. My L 5 speed is out of a 91 wagon and all switches screw into box. Now glad I did not have to set up a switch on levers in the conversion. The lever switch must have been a left over from MY design
Apologies to Vincentvega
SUBYDAZZ
Post by SUBYDAZZ » Thu Oct 19, 2006 12:07 pm
Yes L Series had the switch in different positions depending on year models, if you remove the centre console and can't see the switch under the selector, then it's on the gearbox.
SUBYDAZZ
Post by steptoe » Thu Oct 19, 2006 11:58 pm
my newly acquired 5 spd d/r 3.9 box out of an L is missing both the levers and the Low switch . Hmmph
