Electronic gauge senders
Posted: Fri Feb 02, 2007 10:25 am
by mroberts
Anyone know off-hand if there are existing plugs that could be used to fit oil temperature and pressure, and water temp senders ?
Posted: Fri Feb 02, 2007 10:31 am
by D3V1L
i know that when i fitteed my after market temp guage it worked accuratley of the existing sender unit in the thermostat houseing in my L series., the oil pump houseing down the bottom has a blank hole u can tap a sender into if u get the correct adaptor
dave
Posted: Fri Feb 02, 2007 1:23 pm
by BrennyV
i simply just removed the top oil sender on my engine and replaced it with the new sender unit (just left the old one unpluged).. im fairly sure this only applys to ej tho
