01 b4 ECU reset?
01 b4 ECU reset?
My car ran on a tank of 95 octance cause i couldnt find anything else and after that it basically wouldnt go onto the second turbo. I plugged in the green and black connectors under the dash and immediatly it started making odd noises ... click pssst .. click pssst.. repeating continuously and the exhaust valve motor was turning backwards and forwards (and i noticed the cable was broken) now was my ecu trying to tell me this cable was broken. It didnt flash out any codes just lots of rapid flashing and after i unplugged connectors it ran perfectly again (both turbos top end).
Do these connectors do an ecu reset (i thought they just flashed up the code)
- tim_81coupe
When you check for codes you just connect the black connector(I think.... will check and make sure). Then when you turn the ign on it should flash codes if there are any. The green connect is "self test mode" this you connect if you want to activly check components like injectorts, idle, fans etc etc the mode just cycles thru and buzzes everything.
The code clearing procedure involves connecting both of those conectors and leaving the ignition on for a minute or somthing.... tricky to get right when you want to but you may have fluked it !
Faults that don`t show on the light, unfortunately it often happens that you have a dead or dying component and you`ll never get a code.... the code only happens if its a fatal fault like dead short or open circuit in most cases....
OS
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
