cleaning verdigris off connectors
Posted: Mon May 21, 2007 10:16 am
verdigris...if i spell it right , is the green stuff found corroding copper based components ? found it all over the pins and plugs of my ECU
suspect it is rusty plenum under winscreen allowing water t get near ECU and subaru did not fit a rain coat like Ford now does
wadda you clean this stuff up with ? any clues ?
Posted: Mon May 21, 2007 3:41 pm
by FROG
contact cleaner???????????????????
Posted: Mon May 21, 2007 5:35 pm
isn't that just a wax and grease remover ????????????????????????
Posted: Tue May 22, 2007 8:45 am
by FROG
yea ive had some success with it... may need some elbow grease too
Posted: Tue May 22, 2007 9:30 am
just remembered a radio tech I know, with the dopiest of dogs, a retriever that thinks it is a doberman, time to ask him a trade secret.
thanks GTF
Posted: Tue May 22, 2007 1:01 pm
by Subafury
nah this contact cleaner is just for electrical stuff. i think it would solve your problem
Posted: Tue May 22, 2007 6:43 pm
by BaronVonChickenPants
I've always been disappointed in the results from contact cleaner, only seems to last a couple of months, I have more luck with Inox, leaves an oily residue which stops oxidisation which causes the corrosion.
Jordan.
Posted: Wed May 23, 2007 9:52 am
by fredsub
after you clean it
marine grease works good on connectors, lasts *forever*
hmm sheriff's hat on..........
Posted: Sat May 26, 2007 12:14 am
by subanator
CRC make a product just for this, called Battery Cleaner or something.
It sprays into a foam and neutralises the stuff, still have to scrape off the bigger stuff with a screw driver and wire brush it clean as possible, then hit it again a few times with the spray.
Then coat the terminals with grease or chain lube to protect it from happening again.
Posted: Sat May 26, 2007 12:18 pm
techo said metho or anything like wd40 will do it
