cleaning verdigris off connectors
verdigris...if i spell it right , is the green stuff found corroding copper based components ? found it all over the pins and plugs of my ECU
suspect it is rusty plenum under winscreen allowing water t get near ECU and subaru did not fit a rain coat like Ford now does
wadda you clean this stuff up with ? any clues ?
- BaronVonChickenPants
CRC make a product just for this, called Battery Cleaner or something.
It sprays into a foam and neutralises the stuff, still have to scrape off the bigger stuff with a screw driver and wire brush it clean as possible, then hit it again a few times with the spray.
Then coat the terminals with grease or chain lube to protect it from happening again.
