Altenator EJ conversion, I'm lost
- subarursliberty
Well I'm lost guys with this one. I'm doing the EJ20T conversion on my Leone. Basically I'm lost as to what to do with the alt part of things so I can finish my new power box. I don't know what to patch into what and what extra I have for the EFi stuff. The harness I pinch the wiring from is off an auto legacy. It has 1 additional wire coming off it than what my RS has so i think I can just cut this one and be done with it but the rest well god knows. HELP
- stamp_licker
Have a read of thisshowthread.php?t=4260 it'll help you wire a alt in.I used a late alt on a early loom[ej]which was then spliced into the L fuseable link box and battery .I think i had one heavy white wire left over.Also make sure you get the right plug for the alt makes life a lot easier.
Building a hardcore postie:D
- subarursliberty
Have now. Will have alook later and see how I go.the_postie wrote:Have a read of thisshowthread.php?t=4260 it'll help you wire a alt in.I used a late alt on a early loom[ej]which was then spliced into the L fuseable link box and battery .I think i had one heavy white wire left over.Also make sure you get the right plug for the alt makes life a lot easier.
