electronic distributor upgrade?
Hey,
Just wondering if an electronic distributor is a worthwhile upgrade for a brumby? I believe the stock ones are points based and I'm pretty sure I've read posts on here about it being a decent upgrade.
Does anything need to be modified to put one in or is it just a straight replacement?
Tommo.
Tommo.
- Suby Wan Kenobi
- brumbyrunner
- stamp_licker
It's not just a straight swap... there is some minor wiring envolved from memory and you may have to change your coil or add/remove a balast resister. Has been about 6 years since i did this though so i can't remember spacifics.
Dave
Dave
- BaronVonChickenPants
You don't have to replace the coil but you should, at least a stock electronic coil or something like an MSD Blaster, the stock coil will usually burn out if you just remove the ballast resistor.
Also if you upgrade the coil you might as well re-gap your plugs to ~1.1mm and advance timing to about 12 degrees BTDC.
Jordan.
Jordan.
- Too Many Rubes
I just spent 20 mins typing a how-to for an L-series dizzy into a brumby and when I clicked POST REPLY it disappeared, so I can't be tossed doing it again.
i'll just say it's do-able with some basic engineering skills and an hour and a half to waste.
Mine's purring like a kitten (so far anyway)
If anyone's keen I can post the details for you.
if it helps, I shoved an EA82 dizzy into an EA81 and it fits straight in, despite the shaft bit below the cog - must be cavity in there to take it. This EA82 dizzy only has one ear bolt boss anyway. Somewhere way back some1 mentioned machine something ? spare unused boss maybe, hacksaw is crude but will do the job. You got just two wires on your dizzy ? if so I think you just match the colours to the coil wires , one with yellow goes with the yelow wires at coil, the black with the black.
- Too Many Rubes
The drive gear is different from 81 to 82. I found that i had to fit the 81 drive gear onto the 82 dizzy by drilling a hole in the shaft for the roll pin in the correct position. I then had to cut one of the adjuster ear things off for clearance and move the dizzy around one tooth clockwise for correct timing.
No more flat spots!!! (except for the carby ones)
